Can't restart my Home assistant
Hello, I tried to install HACS but for some reason I can’t restart my HA
I have this message :
2022-04-03 16:38:03 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-03 16:38:05 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-04-03 16:38:05 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=6 from 2022-04-03 20:28:02.877556)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: expected dictionary for dictionary value @ data[‘http’]. Got ‘ssl_certificate:/ssl/fullchain.pem ssl_key://ssl//privatekey.pem’. (See ?, line ?). Please check the docs at HTTP - Home Assistant
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of websocket_api. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for websocket_api: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of config. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for config: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for api: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for webhook: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of diagnostics. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for diagnostics: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for image: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hassio. Setup failed for dependencies: http
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of usb. Setup failed for dependencies: websocket_api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for usb: (DependencyError(…), ‘Could not setup dependencies: websocket_api’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of network. Setup failed for dependencies: websocket_api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for network: (DependencyError(…), ‘Could not setup dependencies: websocket_api’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of search. Setup failed for dependencies: websocket_api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for search: (DependencyError(…), ‘Could not setup dependencies: websocket_api’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of analytics. Setup failed for dependencies: api, websocket_api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for analytics: (DependencyError(…), ‘Could not setup dependencies: api, websocket_api’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cloud. Setup failed for dependencies: http, webhook
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: (DependencyError(…), ‘Could not setup dependencies: http, webhook’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for person: (DependencyError(…), ‘Could not setup dependencies: image’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ssdp. Setup failed for dependencies: network
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for ssdp: (DependencyError(…), ‘Could not setup dependencies: network’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of zeroconf. Setup failed for dependencies: network, api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for zeroconf: (DependencyError(…), ‘Could not setup dependencies: network, api’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: analytics, auth, http, person
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: (DependencyError(…), ‘Could not setup dependencies: analytics, auth, http, person’)
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: api, auth, config, diagnostics, http, onboarding, search, websocket_api
2022-04-03 16:38:05 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: (DependencyError(…), ‘Could not setup dependencies: api, auth, config, diagnostics, http, onboarding, search, websocket_api’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of my. Setup failed for dependencies: frontend
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for my: (DependencyError(…), ‘Could not setup dependencies: frontend’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of spotify. Setup failed for dependencies: http
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for spotify: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, http
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: (DependencyError(…), ‘Could not setup dependencies: frontend, http’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: http
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for history: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tplink. Setup failed for dependencies: network
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for tplink: (DependencyError(…), ‘Could not setup dependencies: network’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for map: (DependencyError(…), ‘Could not setup dependencies: frontend’)
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of media_source. Setup failed for dependencies: http
2022-04-03 16:38:07 ERROR (MainThread) [homeassistant.setup] Setup failed for media_source: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of tts. Setup failed for dependencies: http
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_health. Setup failed for dependencies: http
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Setup failed for system_health: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of energy. Setup failed for dependencies: websocket_api, history
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Setup failed for energy: (DependencyError(…), ‘Could not setup dependencies: websocket_api, history’)
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: http, webhook, person, websocket_api
2022-04-03 16:38:08 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: (DependencyError(…), ‘Could not setup dependencies: http, webhook, person, websocket_api’)
2022-04-03 16:38:10 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, system_health, usb, webhook, zeroconf
2022-04-03 16:38:10 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(…), ‘Could not setup dependencies: cloud, energy, frontend, history, logbook, map, media_source, mobile_app, my, network, person, ssdp, system_health, usb, webhook, zeroconf’)
2022-04-03 16:38:12 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of camera. Setup failed for dependencies: http
2022-04-03 16:38:12 ERROR (MainThread) [homeassistant.setup] Setup failed for camera: (DependencyError(…), ‘Could not setup dependencies: http’)
2022-04-03 16:38:14 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘devolo-967’ for devolo_home_network integration not ready yet: Unable to connect to 192.168.68.76; Retrying in background
2022-04-03 16:38:17 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
2022-04-03 16:47:32 ERROR (MainThread) [homeassistant.components.hassio] The system cannot restart because the configuration is not valid: Invalid config for [http]: expected dictionary for dictionary value @ data[‘http’]. Got ‘ssl_certificate:/ssl/fullchain.pem ssl_key://ssl//privatekey.pem’. (See ?, line ?).
2022-04-03 16:47:32 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548351057296] The system cannot restart because the configuration is not valid: Invalid config for [http]: expected dictionary for dictionary value @ data[‘http’]. Got ‘ssl_certificate:/ssl/fullchain.pem ssl_key://ssl//privatekey.pem’. (See ?, line ?).
You need to fix this and then the rest should be ok. Probably an indentation error. Post that part from your config.yaml file.
OMG it worked ! thank you so much ,you’re a boss :slight_smile:
