Current installation: ubuntu server -> docker -> home assistant
New installation: proxmox -> home assistant (juanmtech manual)
Installed the samba addon to gain acces tot the backup folder of home assistant
I made a snapshot on the ubuntu server machine moved it to proxmox and tried to restore it on proxmox.
When I hit the restore (or wipe and restore) button the home assistant freezes
I tried to make a snapshot on the proxmox system and then tied to restore it with the same result. the system freezes. I only get the notification “Page is not responding”
There is nothing in the logs about the restore action
I would advice to make a full snapshot within HA on old os, Copy config folder to be sure.
Then on new os do a fresh ha install on proxmox using whiskers script, install the addons manually and do restore snapshot in HA.
I did the route you did though. A lot of work to get to qcow2 image and het uit om proxmox backup location.
Tried to install the addons before I did the restore with the same result.
Also did the install with the whiskers script. Same result. (commented on that post with the problem also)
Steps I took.
1 clean install proxmox and home assistant (script)
2 installed the samba addon
3 create an snapshot
4 tried to restore the snap shot (with only the samba addon)
