Installation seems to work fine, but I get the following information when running hass --open-ui. I don’t see a configuration file written to ~/.homeassistant afterwards, either.
$ hass --open-ui
Unable to find configuration. Creating default one in /Users/davidmurr/.homeassistant
File "/Library/Frameworks/Python.framework/Versions/3.5/bin/hass", line 11, in <module>
sys.exit(main())
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/__main__.py", line 375, in main
exit_code = setup_and_run_hass(config_dir, args)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/__main__.py", line 284, in setup_and_run_hass
config_file = ensure_config_file(config_dir)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/__main__.py", line 105, in ensure_config_file
config_path = config_util.ensure_config_exists(config_dir)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/config.py", line 126, in ensure_config_exists
config_path = create_default_config(config_dir, detect_location)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/config.py", line 156, in create_default_config
location_info.longitude)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/util/location.py", line 75, in elevation
return int(float(req.json()['results'][0]['elevation']))
IndexError: list index out of range
