Can't run SSH Add-on
I get this error after installing and trying to run the SSH Add-on:
Image homeassistant/aarch64-addon-ssh not exists for addon_core_ssh
And if you try the other SSH add-on (SSH and Web-terminal from the community add-ons) ?
I solved by installing the 32 bit version of Home Assistant OS
I have the same problem. When I try to run the installed SSH Add-on:
Image homeassistant/aarch64-addon-ssh:9.6.0 does not exist for addon_core_ssh
Any way this can be solved without installing a 32bit build? Shouldn’t an aarch64-build of the addon exist? Does anyone know where these images are being pulled from, so I can check what exists? It doesn’t seem to be https://hub.docker.com/
