Can't save new automations in the UI
Since the last update, few days ago, I can’t save any changes I made in any of my existing automations on the UI, nontheless in new one I’m tring to make.
I just can’t find “Save” button, or any other knd of saving option to use.
What the hell is going on here?
Hi, you would only see a save button pop up in the bottom right corner if there is a change in the automation you are making. Try using fullscreen or scrol down to check if the save button is there.
I have found that the save button is sometimes slow to appear recently - though I think this predates the latest upgrade. Tapping on the next card in the automation usually brings it up.
This is editing in the Android companion app 2022.8.0-full. Haven’t noticed any problems using a PC browser.
Also automation trouble here. I do have the save button and it saves to automations.yaml but new entries are not shown with the rest. Also the counter in the search field is not updating to the new amount of automations.
Also having the same issue. New automations are seen in automations.yaml, but nothing shows up in the UI under automations.
Clear your browser cache.
