I’m experiencing this really odd thing. I installed hassio on a Pi 3 model b+ using the online guide. Followed all steps as should and during the whole day I was able to use the configurator tool within hassio. The next day, I tried to adjust some things in configuration.yalm. As I adjust the things the save button turns red as should be but when I want to click on it, nothing happens. It’s like I’m clicking an empty button. When using the web interface, the button works normal. Anyone an idea what causes this and how to fix this? It doesn’t seem like a lot but it’s really annoying…
I’m new to this so if you have a possible solution, perhaps a little more elaboration than normal is appreciated.
Could you clarify what you mean by that? The save-button is part of the web interface. Are you talking about accessing the configurator from a mobile device?
I am experiencing the same thing. The save button on the WebGUI does not give the usual feedback “File Saved Successfully”. I have got the message only once in the last 50 times I clicked it. It looks like the request does not make it to the server and so no successful saving message appears. The issue is I can issue commands and have my devices work using the WebGUI, but the configurator’s save button does not behave appropriately.
Same here, I can save files in url http://192.168.1.2:3218 but with https://mydomain/configurator I can’t…it’s strange because api commands are working fine (reboot for example or I can see the entities).
The logs say nothing about that
