Can't see advanced mode after activated
Hello
I can’t see advanced mode after activated in my new installation on docker in DSM… (DSM 7.2-64570 Update 1)
I tried everything I read, clear cache, reboot HA, etc
my version: Home Assistant 2023.8.4
Interface: 20230802.1 - latest
Any ideas?
Tks
What do you expect to see ?
menu add-ons in configurations
Add-ons can been seen without advanced mode, only certain add-ons are hidden without advanced mode.
Click settings → System → Repairs → 3 dots in the upper left corner → System Information
What is shown there ?
Assuming that means you installed using either container or core.
Addons are only available in HAOS and Supervised installs. Addons are basically just software for HA in precanned containers, but you’re already running docker and it’s assumed you are knowledgeable about management of your containers… So in that case you should look for various containerized versions of the software you’re looking for.
System Information
version core-2023.8.4
installation_type Home Assistant Container
dev false
hassio false
docker true
user root
virtualenv false
python_version 3.11.4
os_name Linux
os_version 4.4.302+
arch x86_64
timezone Europe/Lisbon
config_dir /config
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Dashboards
dashboards 1
resources 0
views 1
mode storage
Recorder
oldest_recorder_run 25 de agosto de 2023 19:57
current_recorder_run 27 de agosto de 2023 11:25
estimated_db_size 1.66 MiB
database_engine sqlite
database_version 3.41.2
You are running HA Container, so no add-ons. You have to run HA OS or HA Supervised to have add-ons.
ok, finally I understand… next I try to install Home Assistant OS on Synology NAS (918+) using VMM
next thing, buy more memory!
soon I post the result.
tks
