After configure mqtt broker and zigbee2mqtt I can’t see the decives.
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
2019-09-10T00:50:57: PM2 log: Launching in no daemon mode
2019-09-10T00:50:59: PM2 log: App [npm:0] starting in -fork mode-
2019-09-10T00:50:59: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.5.1
> node index.js
zigbee2mqtt:info 9/10/2019, 12:51:34 AM Logging to directory: '/share/zigbee2mqtt/log/2019-09-10.00-51-28'
zigbee2mqtt:info 9/10/2019, 12:51:35 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
zigbee2mqtt:info 9/10/2019, 12:51:35 AM Starting zigbee-shepherd
zigbee2mqtt:info 9/10/2019, 12:51:38 AM zigbee-shepherd started
zigbee2mqtt:info 9/10/2019, 12:51:38 AM Coordinator firmware version: '20190608'
zigbee2mqtt:info 9/10/2019, 12:51:38 AM Currently 1 devices are joined:
zigbee2mqtt:info 9/10/2019, 12:51:38 AM 0x00158d0001a66a8f (0x00158d0001a66a8f): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
zigbee2mqtt:warn 9/10/2019, 12:51:38 AM `permit_join` set to `true` in configuration.yaml.
zigbee2mqtt:warn 9/10/2019, 12:51:38 AM Allowing new devices to join.
zigbee2mqtt:warn 9/10/2019, 12:51:38 AM Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info 9/10/2019, 12:51:38 AM Zigbee: allowing new devices to join.
zigbee2mqtt:info 9/10/2019, 12:51:38 AM Connecting to MQTT server at mqtt://core-mosquitto
zigbee2mqtt:info 9/10/2019, 12:51:38 AM zigbee-shepherd ready
zigbee2mqtt:info 9/10/2019, 12:51:40 AM Connected to MQTT server
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":89,"battery":100,"voltage":3025}'
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'homeassistant/sensor/0x00158d0001a66a8f/click/config', payload '{"icon":"mdi:toggle-switch","value_template":"{{ value_json.click }}","state_topic":"zigbee2mqtt/0x00158d0001a66a8f","json_attributes_topic":"zigbee2mqtt/0x00158d0001a66a8f","name":"0x00158d0001a66a8f_click","unique_id":"0x00158d0001a66a8f_click_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0001a66a8f"],"name":"0x00158d0001a66a8f","sw_version":"Zigbee2mqtt 1.5.1","model":"Aqara wireless switch (WXKG11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'homeassistant/sensor/0x00158d0001a66a8f/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/0x00158d0001a66a8f","json_attributes_topic":"zigbee2mqtt/0x00158d0001a66a8f","name":"0x00158d0001a66a8f_battery","unique_id":"0x00158d0001a66a8f_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0001a66a8f"],"name":"0x00158d0001a66a8f","sw_version":"Zigbee2mqtt 1.5.1","model":"Aqara wireless switch (WXKG11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'homeassistant/sensor/0x00158d0001a66a8f/linkquality/config', payload '{"unit_of_measurement":"-","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d0001a66a8f","json_attributes_topic":"zigbee2mqtt/0x00158d0001a66a8f","name":"0x00158d0001a66a8f_linkquality","unique_id":"0x00158d0001a66a8f_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0001a66a8f"],"name":"0x00158d0001a66a8f","sw_version":"Zigbee2mqtt 1.5.1","model":"Aqara wireless switch (WXKG11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info 9/10/2019, 12:51:40 AM MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.5.1","commit":"unknown","coordinator":20190608,"log_level":"info","permit_join":true}'
zigbee2mqtt:info 9/10/2019, 12:52:30 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:52:30 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:54:18 AM Successfully reenabled joining
zigbee2mqtt:info 9/10/2019, 12:55:31 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:31 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:33 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":99,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:33 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":99,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:38 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:38 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":94,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:41 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:41 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:45 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:45 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:46 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:46 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:47 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":102,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:47 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":102,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:48 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:48 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":105,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:55:50 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":115,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:55:50 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":115,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:56:29 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":118,"battery":100,"voltage":3025,"click":"single"}'
zigbee2mqtt:info 9/10/2019, 12:56:29 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":118,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:56:31 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":118,"battery":100,"voltage":3025,"click":"double"}'
zigbee2mqtt:info 9/10/2019, 12:56:31 AM MQTT publish: topic 'zigbee2mqtt/0x00158d0001a66a8f', payload '{"linkquality":118,"battery":100,"voltage":3025,"click":""}'
zigbee2mqtt:info 9/10/2019, 12:56:58 AM Successfully reenabled joining
zigbee2mqtt:info 9/10/2019, 12:59:38 AM Successfully reenabled joining
And mqtt broker log:
[00:50:08] INFO: Setup mosquitto configuration
[00:50:08] WARNING: SSL not enabled - No valid certs found!
[00:50:08] INFO: Found local users inside config
[00:50:09] INFO: Initialize Hass.io Add-on services
[00:50:09] INFO: Initialize Home Assistant discovery
[00:50:09] INFO: Start Mosquitto daemon
1568073009: mosquitto version 1.6.3 starting
1568073009: Config loaded from /etc/mosquitto.conf.
1568073009: Loading plugin: /usr/share/mosquitto/auth-plug.so
1568073009: ├── Username/password checking enabled.
1568073009: ├── TLS-PSK checking enabled.
1568073009: └── Extended authentication not enabled.
1568073009: |-- *** auth-plug: startup
1568073009: Opening ipv4 listen socket on port 1883.
1568073009: Opening ipv6 listen socket on port 1883.
1568073009: Opening websockets listen socket on port 1884.
1568073009: Warning: Mosquitto should not be run as root/administrator.
1568073098: New connection from 172.30.33.1 on port 1883.
[INFO] found mqtt on local database
1568073099: New client connected from 172.30.33.1 as mqttjs_80f668d5 (p2, c1, k60, u'mqtt').
1568073121: New connection from 172.30.32.1 on port 1883.
1568073121: New client connected from 172.30.32.1 as auto-AF6C825F-FFC1-1EFD-2F18-915ACB8E8193 (p2, c1, k60).
And my configuration file:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
#automation: !include automations.yaml
script: !include scripts.yaml
mqtt:
broker: core-mosquitto # This will have to be your mqtt broker, Mosquitto addon is recommended.
discovery: true
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: off
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600 # Updated this to the number of seconds you wish
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
automation:
- id: enable_zigbee_join
alias: Enable Zigbee joining
hide_entity: true
platform: state
entity_id: input_boolean.zigbee_permit_join
to: 'on'
- service: mqtt.publish
topic: zigbee2mqtt/bridge/config/permit_join
payload: 'true'
- service: timer.start
entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
alias: Disable Zigbee joining
- entity_id: input_boolean.zigbee_permit_join
platform: state
to: 'off'
- data:
payload: 'false'
- data:
service: timer.cancel
hide_entity: true
- id: disable_zigbee_join_timer
alias: Disable Zigbee joining by timer
hide_entity: true
- platform: event
event_type: timer.finished
event_data:
payload: 'false'
- service: input_boolean.turn_off
It is a recently and clean install with mosquitto and zigbee2mqtt addon.
Where should I look for clues?
