Hi there. Newbie here. I will try to be clear and concise
I have purchased a second-hand Dell OptiPlex 3050 with 8GB ram and 128GB SSD. It has windows 10 installed currently.
I am trying to flash the SSD with HA OS.
I have followed the instructions, booted to Ubuntu using a flash drive, loaded Balena Etcher for Ubuntu on another flash drive, copied the HA OS to the Ubuntu Downloads and also Balena Etcher. I can open Etcher and it sees the Flash Drives, but it doesn’t see the SSD.
I have also tried using terminal with the command “lsblk” to list the disks. The 128GB SSD is not shown there, either.
I opened the case and it seems there is some sort of flash disk, not what I would call a regular SSD. I have never seen it before, but I can see it says 128 GB.
I can’t help you exactly, as I don’t know the BIOS of this machine.
But very big chance, that BIOS is exactly, where you want to have a look.
The NVMe drive (that’s the kind of SSD, you have) can be just protected against overwriting inside the BIOS.
Also have a look there on the UEFI settings.
I had kind of same problem with some HP thin clients, and needed to reset BIOS totally to get them accept new OS.
(total reset - in most cases: remove backup battery on the motherboard, press POWER button for at least 20 seconds, put battery back. In some cases there is even a jumper on the board, that needs to be removed temporarily)
Thanks for the reply. I did check the BIOS and I can see the NVMe SSD in the bios. It runs Windows, so I know it is working. I went back to the video that recommended the hardware and note that it removed the NVMe SSD and flashed it from a windows machine. This requires an adaptor ($29 from Amazon). I then realised I could by a SATA 2.5" SSD for $29, so I have purchased that instead. I will try again on the weekend with my new drive. The added benefit is I get to keep my device as a dual boot machine.
Thanks. I have UEFI and secure boot sorted. the BIOS definitely has raid configured. I was reluctant to touch that (yesterday) as I didn’t’ know what effect it would have. I have ordered the SATA SSD now, so I will wait to see if that sorts it, otherwise I will try some of these suggestions.
Thanks for the advice. I had already purchased the SATA ssd, so I will stick with that for now. I may come back to the NVMe if performance is an issue, as suggested.
I still have issues, but different issues now. I will browse for solutions and create a new thread if needed.
