Can't see the Automations editor in Frontend
Hi there!
I wanted to try the Automations editor, but I do not get the “Configuration” option in Frontend.
I have moved my automations to automations.yaml and linked to it from configuration.yaml. Everything works fine, but I cannot see the buttons to start the editor. I am running 0.51.2. docker on Synology
Hi @Trebor5, you have to enable config in your configuration.yaml
Thanks @VDRainer that solved it. :slight_smile:
