Hi all!
I am having issues removing bad statistics (spikes in my graphs) and can’t get my head around it.
I’ve succeeded once removing directly from the DB (with ssh and sqlite, and thanks to this forum so full of great material, thanks!), but failed miserably in my next attempts. I am sure I will manage if I spend a few more hours, but if I have to do this for every time that I have a spike (e.g. every time I install a new sensor, before it falls into its final location) I will simply not do it. Please don’t bother recommending how to do this this way, there are plenty of forum threads about this already.
Luckily home assistant should have a relatively new feature that allows you to remove statistics by going into Debug → Statistics and clicking on the right graph icon on the right. The only problem is… that for some reason these graph icons do not show up for me! At the beginning I thought it was a problem of my installation, being a new feature and all… but last night I’ve seen that a new metric has the graph icon indeed, while all the other (important) ones do not have such graph icon. I did not do anything special when I added this sensor.
Does any of you know what might be going on? Why do some sensors have the icon to remove statistics and some (almost all, in my case) don’t? How can I enable the icon in those?
Thanks a lot for your help!
