When my setpoint for my thermostat is the lowest number quantity on the graph I’m unable to see when the heater has run. In the screenshot above when the thermostats setpoint was set to 65 I loose the ability to see when the heater was running. Is there a way to force lovelace to always set the range +/- 3 degrees from the min/max value displayed on the graph?
Same issue here, nothing under the setpoint is displayed, so activity of the heater is always hidden under the bottom line.
Tomorrow I will make an issue on Git.
