Afternoon All,
I’ve got the following automation:
- alias: "Computer Control"
platform: state
entity_id: input_boolean.pc_power_on
service_template: >
{% if is_state('input_boolean.pc_power_on', 'off') %}
switch.turn_off
{% else %}
switch.turn_on
{% endif %}
entity_id: switch.computer
service_template: >
switch.turn_off
{% else %}
switch.turn_on
{% endif %}
entity_id: switch.plug_005a
50% Works
If I turn it off the plug turns on an off as desired. The switch.computer does not get called though…
If I call switch.computer manually it works fine. The bit that confuses me is the two actions are identical bar the switch name.
