Hi guys,
I have HA on a docker.
https://localhost:8123
I cannot access it from my laptop or HA app on the same wifi network.
docker IP 172.17.x.x.
pc IP 192.168.x.x
I opened the port on the firewall still no luck.
tried
https:// 172.17.x.x:8123
https:// 17.x.x.x:8123
https://homeassistant.local:8123
and other combinations.
n.b.d this is not hass.io
just homeassistant on the docker
What config am I missing?
Do I need to configure the network settings in portainer?
either set the option for the container to use the host network
- docker command line configuration is
--net=host
or map (the option is actually to “publish”) the port on the container
-p 8123:8123
Thanks for that.
Haven’t had any success yet.
I see the portainer is on a bridge network with ports 8000 and 9000
The HA container is on a bridge network with port 8123.
If I enter the HA container and try to add it to the host it does not allow me to.
try various command line entries from powershell but haven’t had luck yet.
First, no need to hide your ip addresses, these are local addresses.
What do you mean with
which firewall?
Did you try to acces it through http://192.168.x.x:8123?
Can you ping 192.168.x.x from the machine you trying to access HA?
Seems to be working now with http://192.168.x.x:8123 but now I can’t remember my password!
Thanks!
Just for your info, the IP starting with 172. is the IP generated by docker and used in the docker network, that’s why you couldn’t access it from another machine.
