Hi all.
I have the following automation
alias: guest light automation
description: guest automation for lights on/off
- type: motion
platform: device
device_id: bf4f40f0e5729debfffc56ddd7e5f576
entity_id: binary_sensor.guest_motion
domain: binary_sensor
- type: no_motion
platform: device
condition:
- condition: state
entity_id: input_boolean.guest_autoswitch
state: "on"
- choose:
- conditions:
- condition: trigger
- condition: time
before: "22:30:00"
weekday:
- sun
- sat
- fri
- thu
- wed
- tue
- mon
after: "07:00:00"
sequence:
- service: light.turn_on
brightness: 255
color_temp: 337
entity_id: light.guest
- conditions:
- condition: time
after: "22:30:00"
before: "07:00:00"
weekday:
- sun
- sat
- fri
- thu
- wed
- tue
- mon
sequence:
brightness: 40
rgb_color:
- 58
- 136
- 254
- conditions:
- condition: state
entity_id: binary_sensor.guest_contact
state: "off"
for:
hours: 0
minutes: 10
seconds: 0
sequence:
- service: light.turn_off
data: {}
- conditions:
- condition: state
state: "on"
for:
hours: 0
minutes: 3
seconds: 0
sequence:
data: {}
mode: single
the lights coming on do work out reliably but im struggling with the turn off part. I cant seem to get it to work to turn off based on the condition of the door being closed/open. if the door is open I want it to count 3:00 minutes and then turn off and when the door is closed count 10:00 and then turn off.
clearly im doing something wrong in the automation any help would be very appreciated!
best
Z
