Can't seem to get M5stack HX711 scale to work
I am trying to use ESPhome together with the M5Stack Scales kit (a HX711 with four half-bridge resistive strain gauges) and a M5Stack Basic Core v2.6 development kit to create a scale.
I currently have the following configuration:
esphome:
  friendly_name: esphome-coffee-scale
esp32:
  board: m5stack-core-esp32
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "REDACTED"
ota:
  password: "REDACTED"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Coffee-Scale"
  manual_ip:
    static_ip: 192.168.1.162
    gateway: 192.168.1.1
    subnet: 255.255.255.0
captive_portal:
spi:
  clk_pin: 18
  mosi_pin: 23
  miso_pin: 19
color:
  - id: my_blue
    red: 94%
    green: 97%
    blue: 100%
font:
  - file: "gfonts://Roboto"
    glyphs: '!"%()+,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz/³µ'
display:
  - platform: ili9xxx
    model: M5STACK
    cs_pin: 14
    dc_pin: 27
    reset_pin: 33
    rotation: 0
    lambda: |-
      Color RED(1,0,0);
      Color BLUE(0,0,1);
      Color WHITE(1,1,1);
      it.printf(0, 0, id(font_roboto_15), id(my_blue), COLOR_OFF, TextAlign::TOP_LEFT, "The current temperature is %.1f °C", id(living_room_temp).state);
      it.printf(0, 20, id(font_roboto_15), id(my_blue), COLOR_OFF, TextAlign::TOP_LEFT, "The current load value is %.1f", id(hx711_value).state);
  - platform: hx711
    dout_pin: GPIO21
    clk_pin: GPIO22
    gain: 128
    update_interval: 30s
  - platform: homeassistant
    entity_id: sensor.living_room_temperature
binary_sensor:
  - platform: gpio
    pin:
      number: 38
      inverted: true
    on_click:
      then:
        - switch.toggle: backlight
# GPIO pin of the display backlight
switch:
  - platform: gpio
    pin: 32
    restore_mode: ALWAYS_ON
However when running this, I get the following message in the logs [hx711:037]: HX711 is not ready for new measurements yet! and the display shows “nan” for the current load value.
I suspect I’m missing something quite obvious, but I’ve been stuck on this for a while now and have run out of ideas.
Any help would be appreciated!
Cheers,
Dinyar
How is your scales kit actually connected?
Maybe some pin mapping confusion…
Hi @Karosm,
Yeah, I think this was the problem. It looks like the pins that are connected to the grove port can’t be used as GPIO, but somehow are stuck in I2C mode. When I instead use one of the GPIOs that are exposed differently on the Core it works.
Cheers,
Dinyar
Hello. I have one of these scales and I’m trying to figure out how to get it working. Would you mind going into more detail about how you got it working and/or pasting your YAML configuration? It would be much appreciated!
I wrote the solution here:
Thanks, I’ll give this a shot!
This is surprising to hear though, because I chatted with an ESPHome dev and they seemed certain a new component (i.e. a code change) would need to be added before it could work.
Did you get it to work?
I tried various examples from the forum but no luck so far.
Yes, I got this working perfectly including a button for calibration. See this comment and let me know if you’re not able to get it working yourself:
You should just be able to copy/paste that config. However, as with anything in ESPHome, ensure the GPIO pins (here, for the i2c component) align with how you have the scale connected to your ESP device.
It took a bit of fiddling, but somehow, it works now. Thanks for your support.
