I use the mobile app to recoginize the device. I’m able to scan the matter qr code and it goes through its process up until I think its says something to the effect ‘importing into home assistant’ at that point it fails ‘something went wrong’.
I have latest HA installed 2023.11.3
I also have the matter server running in docker.
I’ve follow digiblurs instructions on setting this all up but can’t seem to get past this point.
Same deal. I got these exact units connected to google home but can’t get it to connect to home assistant. Connects to the network, sets credentials but fails to connect to home assistant
I also have a KS225. HA does not see the switch… even if I add it the ‘old way’ through the Kasa App and connect it to WiFi like all my other Kasa switches, it does not appear in HA… and if I tell it to discover the KS225’s IP address, same result.
Attempts to add it via matter fail at the last step and the switch can’t be added.
Guessing the recently released Kasa products aren’t quite supported in the Kasa addon yet?
My KS225 appeared with the 2024.02 update, woo! It is asking for credentials. Which credentials are these? I tried my HA login and my TPLink Kasa login, no dice.
I know this is an old thread. If you need to Authenticate does this means I need to allow the Kasa device to access the internet? I’m debating if I should get the matter KS225 vs old dimmers HS220. Rather keep it fully local.
