Cant seems to find SSH in the Hassio Addons Page
I am running Hassio on a new Raspberry Pi 4 and installed the latest version - 109.3. However, I am unable to find and install SSH in the Addons Page. I have tried to reformat the sd card and install hassio again but still no SSH in the Addons Page. Please help!
SSH is now for ā€˜advanced’ users only. Click in the lower left corner on your name, and enable advanced mode. Then you will be able to see the SSH add-on.
Sorry but that has to be one of the dumbest decisions in the long line of recent dumb decisions. How are new users supposed to recover from a failed front end?
It’s not safe/recovery mode. That never works.
I know, but I don’t make the decisions.
Thanks @francisp for the quick response! Yes, I have found it! On to my setup.
Yeah I wasn’t blaming you.
Hi @francisp,
I have the following error with the SSH:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] cli: applying...
[fix-attrs.d] cli: exited 0.
[fix-attrs.d] profile: applying...
[fix-attrs.d] profile: exited 0.
[fix-attrs.d] ssh: applying...
[fix-attrs.d] ssh: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] keygen.sh: executing...
[05:38:09] INFO: Restoring host keys...
cp: can't stat '/data/host_keys/*': No such file or directory
[cont-init.d] keygen.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I am unable to start SSH at all with the default configuration or with my own config as follows:
authorized_keys:
    ssh-rsa XXX..... rsa-key-20190209
password: ''
took me 30 minutes to figure this ā€œadvanced modeā€ out … this is complete bullshit… finding the right usb mount is not really advanced. at least not until it’s not listed anywhere in the UI
I literally made an account here and necro’d this thread to say thank you for telling me how to enable SSH and to second the opinion that hiding any add-on for ā€œadvanced usersā€ is hands down one of the stupidest things I’ve ever seen. This has wasted hours of my time as I moved from docker to a VM to physical hardware thinking SSH was hidden because I wasn’t on a full fledged version of home assistant.
If I’m installing any add-on I’m assuming the risk that comes with that add-on.
