Cant select/map attributes 'title' in template
using
{% set noti = states.persistent_notification
   |selectattr('state','eq','notifying')|map(attribute='entity_id')|list %}
{{noti}}
works fine and returns a list of ‘on’ notifications with the entity_id. However, I want the show a list of titles, using
   |selectattr('state','eq','notifying')|map(attribute='title')|list %}
{{noti}}
which does nothing (shows ‘Undefined’ in the list for the number of ‘on’ notifications)
Ive checked a current persistent notification itself,
{{states.persistent_notification.rss_feed_home_assistant_0_107.attributes.title}}
which works fine:
this is the full attributes list of the notification:
had a long day of puzzling, so must be overlooking the obvious… please have a look? thanks!
{% set noti = states.persistent_notification |selectattr('state','eq','notifying')|map(attribute='attributes.title')|list %} {{noti}}
one more Petro:
why do I have to use this:
            |selectattr('state','eq','notifying')  %}
            {% if noti|list|length == 0 %} No persistent notifications
            {% else %}
            |selectattr('state','eq','notifying')|map(attribute='attributes.title')|list|join(', \n')}}
 {% endif %}
and cant I use:
          notifications: >
            {% else %}
            {{noti|map(attribute='attributes.title')|list|join(', \n')}}
            {% endif %}
I cant seem to use the {{noti}} in both if and else, only in either of the if or else…
because noti is a generator. Once it’s used once, you can’t use it again. Convert it to a list and you’ll be able to use it multiple times
            |selectattr('state','eq','notifying') | list %}
{% if noti|length == 0 %} No persistent notifications
{% else %}
{% endif %}
I see, thanks!
now I can play with the various options again, nice:
              |list %}
{% else %}
{{noti|join(', \n')}}
{% endif %}
to use it in my template sensor:
      persistent_notifications:
        value_template: >
                        |list %}
          {{noti|count}}
        attribute_templates:
          notifications: >
                          |list %}
            {% else %}
            {% endif %}
though the value_template could probably just be
        {{states.persistent_notification|list|length}}
have a good weekend!
