I’m having a problem with the alarm-panel card in Lovelace. It shows just like it should and it will take input by either clicking the numbers, or by typing the numbers on the keyboard. However, it does nothing when I click on either Arm Home or Arm Away. If I bring up the alarm More-Info card in States <>, it works perfectly. It is only in Lovelace that it is not working correctly.
alarm_control_panel:
- platform: manual_mqtt
state_topic: home/alarm
command_topic: home/alarm/set
code: !secret alarm_code
- type: vertical-stack
cards:
- type: alarm-panel
entity: alarm_control_panel.ha_alarm
