Hi!
Having some issues setting names on history graph entities. Not sure if I’m doing something wrong or if it’s a bug, so I thought I’d ask you guys before submitting to the github tracker (and would it go in the frontend, home assistant or hassio tracker?).
Card config:
entities:
- entity: sensor.FilamentHumidity
- entity: sensor.FilamentHumidity2
- entity: sensor.FilamentTemperature
- entity: sensor.FilamentTemperature2
hours_to_show: 24
refresh_interval: 0
title: Filament Boxes
type: history-graph
configuration.yaml example (all of these sensors are setup the exact same way):
- platform: mqtt
unit_of_measurement: '°C'
state_topic: "sensor/filament_temperature"
Home assistant 0.100.3
Frontend 20191002.2
HassOS 2.11
Any ideas/anyone else with the same problem? Thanks!
