Can't set parameter using zwave.set_config_parameter
I Call Service:
In logs I see:
2020-01-14 12:07:48.689 Info, Node006, Value::Set - COMMAND_CLASS_CONFIGURATION - Максимальная ширина коридора температурой - 5 - 1 - 10
2020-01-14 12:07:48.689 Info, Node006, Configuration::Set - Parameter=5, Value=10 Size=2
2020-01-14 12:07:48.689 Detail, Node006, Queuing (Send) ConfigurationCmd_Set (Node=6): 0x01, 0x0d, 0x00, 0x13, 0x06, 0x06, 0x70, 0x04, 0x05, 0x02, 0x00, 0x0a, 0x25, 0x0a, 0xb7
2020-01-14 12:07:48.689 Detail, Node006, Queuing (Send) ConfigurationCmd_Get (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x70, 0x05, 0x05, 0x25, 0x0b, 0xbd
2020-01-14 12:07:48.690 Detail,
2020-01-14 12:07:48.690 Info, Node006, Sending (Send) message (Callback ID=0x0a, Expected Reply=0x13) - ConfigurationCmd_Set (Node=6): 0x01, 0x0d, 0x00, 0x13, 0x06, 0x06, 0x70, 0x04, 0x05, 0x02, 0x00, 0x0a, 0x25, 0x0a, 0xb7
2020-01-14 12:07:48.696 Detail, Node006,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-14 12:07:48.696 Detail, Node006,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-14 12:07:48.709 Detail, Node006,   Received: 0x01, 0x05, 0x00, 0x13, 0x0a, 0x00, 0xe3
2020-01-14 12:07:48.710 Detail, Node006,   ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2020-01-14 12:07:48.710 Info, Node006, Request RTT 19 Average Request RTT 18
2020-01-14 12:07:48.710 Detail,   Expected callbackId was received
2020-01-14 12:07:48.710 Detail,   Expected reply was received
2020-01-14 12:07:48.710 Detail,   Message transaction complete
2020-01-14 12:07:48.710 Detail, Node006, Removing current message
2020-01-14 12:07:48.710 Info, Node006, Sending (Send) message (Callback ID=0x0b, Expected Reply=0x04) - ConfigurationCmd_Get (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x70, 0x05, 0x05, 0x25, 0x0b, 0xbd
2020-01-14 12:07:48.716 Detail, Node006,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-14 12:07:48.716 Detail, Node006,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-14 12:07:48.728 Detail, Node006,   Received: 0x01, 0x05, 0x00, 0x13, 0x0b, 0x00, 0xe2
2020-01-14 12:07:48.728 Detail, Node006,   ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2020-01-14 12:07:48.728 Info, Node006, Request RTT 17 Average Request RTT 17
2020-01-14 12:07:48.728 Detail,   Expected callbackId was received
2020-01-14 12:07:48.735 Detail, Node006,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x06, 0x05, 0x70, 0x06, 0x05, 0x01, 0x1e, 0x9f
2020-01-14 12:07:48.736 Detail,
2020-01-14 12:07:48.736 Info, Node006, Response RTT 25 Average Response RTT 24
2020-01-14 12:07:48.736 Detail, Node006, Refreshed Value: old value=30, new value=30, type=short
2020-01-14 12:07:48.736 Detail, Node006, Changes to this value are not verified
2020-01-14 12:07:48.736 Info, Node006, Received Configuration report: Parameter=5, Value=30
2020-01-14 12:07:48.736 Detail, Node006,   Expected reply and command class was received
2020-01-14 12:07:48.736 Detail, Node006,   Message transaction complete
2020-01-14 12:07:48.736 Detail, Node006, Removing current message
2020-01-14 12:07:48.736 Detail, Node006, Notification: ValueChanged
2020-01-14 12:07:55.053 Detail, Node006, Polling: COMMAND_CLASS_SENSOR_MULTILEVEL index = 1 instance = 1 (poll queue has 0 messages)
2020-01-14 12:07:55.054 Detail, Node006, Queuing (Poll) SensorMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x31, 0x04, 0x25, 0x0c, 0xfd
2020-01-14 12:07:55.054 Info, Node006, Sending (Poll) message (Callback ID=0x0c, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x31, 0x04, 0x25, 0x0c, 0xfd
2020-01-14 12:07:55.060 Detail, Node006,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-14 12:07:55.060 Detail, Node006,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-14 12:07:55.072 Detail, Node006,   Received: 0x01, 0x05, 0x00, 0x13, 0x0c, 0x00, 0xe5
2020-01-14 12:07:55.072 Detail, Node006,   ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2020-01-14 12:07:55.073 Info, Node006, Request RTT 17 Average Request RTT 17
2020-01-14 12:07:55.073 Detail,   Expected callbackId was received
2020-01-14 12:07:55.080 Detail, Node006,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x06, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xff, 0x1f
2020-01-14 12:07:55.081 Detail,
2020-01-14 12:07:55.081 Info, Node006, Response RTT 25 Average Response RTT 24
2020-01-14 12:07:55.081 Info, Node006, Received SensorMultiLevel report from node 6, instance 1, Temperature: value=25.5C
2020-01-14 12:07:55.081 Detail, Node006, Refreshed Value: old value=25.5, new value=25.5, type=decimal
2020-01-14 12:07:55.081 Detail, Node006, Changes to this value are not verified
2020-01-14 12:07:55.082 Detail, Node006,   Expected reply and command class was received
2020-01-14 12:07:55.082 Detail, Node006,   Message transaction complete
2020-01-14 12:07:55.082 Detail, Node006, Removing current message
2020-01-14 12:07:55.082 Detail, Node006, Notification: ValueChanged
2020-01-14 12:08:02.585 Detail, Node006, Polling: COMMAND_CLASS_THERMOSTAT_MODE index = 0 instance = 1 (poll queue has 0 messages)
2020-01-14 12:08:02.585 Detail, Node006, Queuing (Poll) ThermostatModeCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x40, 0x02, 0x25, 0x0d, 0x8b
2020-01-14 12:08:02.585 Info, Node006, Sending (Poll) message (Callback ID=0x0d, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x40, 0x02, 0x25, 0x0d, 0x8b
2020-01-14 12:08:02.591 Detail, Node006,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-14 12:08:02.591 Detail, Node006,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-14 12:08:02.603 Detail, Node006,   Received: 0x01, 0x05, 0x00, 0x13, 0x0d, 0x00, 0xe4
2020-01-14 12:08:02.603 Detail, Node006,   ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2020-01-14 12:08:02.603 Info, Node006, Request RTT 17 Average Request RTT 17
2020-01-14 12:08:02.603 Detail,   Expected callbackId was received
2020-01-14 12:08:02.610 Detail, Node006,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x40, 0x03, 0x01, 0xb5
2020-01-14 12:08:02.611 Detail,
2020-01-14 12:08:02.611 Info, Node006, Response RTT 25 Average Response RTT 24
2020-01-14 12:08:02.611 Detail, Node006, Refreshed Value: old value=1, new value=1, type=list
2020-01-14 12:08:02.612 Detail, Node006, Changes to this value are not verified
2020-01-14 12:08:02.612 Info, Node006, Received thermostat mode: Heat
2020-01-14 12:08:02.612 Detail, Node006,   Expected reply and command class was received
2020-01-14 12:08:02.613 Detail, Node006,   Message transaction complete
2020-01-14 12:08:02.613 Detail, Node006, Removing current message
2020-01-14 12:08:02.614 Detail, Node006, Notification: ValueChanged
Why it not changed parameter?
p.s. in zwcfg_0x0161de7c.xml no this parameter, but in device manual http://rus.z-wave.me/drive/?file=16ef68ed7221041120492bd287849fdd53f3 it has parameters.
Dmitry
Probably need to add size: 1 to your service data.
