I have z-wave floor thermostat. I try to set temperature:
Run this automation:
But nothing happened… Floor not heat. Attribute not changed from null. Please, help! What’s wrong?
In your automation:
isn’t it hvac_modes: heat ? with a s at the end.
Odd the device seems to be missing the hvac_mode
‘off’.
already opened an issue in GitHub for that (12 days ago):
Your issue is different from the issue the OP has posted.
If you would like to read & chech the solution I just wrote there, it might solve the issue (just an hunch)…
OP’s issue is missing some information in the XML from the looks of it. Hopefully the modifications I posted in your issue help’s them.
