Can't set Zwave parameters anymore
I dont know if this should be in Zwave forum or here. I set Z wave parameters via a MQTT node. Now they dont work anymore. Heres the flow that used to work. And here’s the error I get when I open of MQTT Explorer.
[{"id":"9644b8ea6ce322ad","type":"tab","label":"Flow 4","disabled":false,"info":"","env":[]},{"id":"5cb0c4c78c2820a9","type":"inject","z":"9644b8ea6ce322ad","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":355,"y":300,"wires":[["e817e332a7d53635"]]},{"id":"e817e332a7d53635","type":"function","z":"9644b8ea6ce322ad","name":"Office 67","func":"msg.payload = {     \n    \"args\": [     {       \n        \"commandClass\": 112,       \n        \"nodeId\": 67,       \n        \"property\": 16 },     \n        \"set\", [16, 50268760, 4]]\n    }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":300,"wires":[["dee33c0969997b04"]]},{"id":"dee33c0969997b04","type":"change","z":"9644b8ea6ce322ad","name":"Set topic","rules":[{"t":"set","p":"topic","pt":"msg","to":"zwave/_CLIENTS/ZWAVE_GATEWAY-Mosquitto/api/sendCommand/set","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":695,"y":300,"wires":[["5512f228eb540dfd"]]},{"id":"5512f228eb540dfd","type":"mqtt out","z":"9644b8ea6ce322ad","name":"","topic":"","qos":"","retain":"","broker":"d66e875.2455a78","x":865,"y":300,"wires":[]},{"id":"d66e875.2455a78","type":"mqtt-broker","name":"re","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Apparently because I was late to the update, they changed how you have to command it. Heres what works now.
msg.payload = {
    "args": [
        { "commandClass": 112, "nodeId": 67 },
        "set",
        [{ parameter: 16, value: 50268713, valueSize: 4 }]
return msg;
