Hi all, so ive plugged the HA green in and mobile app finds it (iphone) i click on found server, asks for a login, username and password? Ive not made and im stuck there, same from browser localxxxx asks for the login so i cant do anything
Hi no just — as shown, but i did a «box» reset , with push button n power supply method, then it came wirh the «create new home» page and booted «right» i might got a used unit since i was pushed to login? Idk
I guess it was preloaded so when powering on, you just had to create a user whereas with the reset you did, you started from scratch.
Please give something back to the community and take the time to mark the post that has the solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so the solution can be helpful to others and prevents that someone else steps in to try to help.
