I have HA set up on Docker (Container Manager) on my Synology NAS. I am using Synology’s built-in DDNS and Reverse Proxy with a Lets Encrypt SSL wildcard certificate.
When I try to install SmartThings integration, I get to this screen:
If I go to the callback URL on that page, I get an ERR_INVALID_RESPONSE
If I continue on anyways, and input my personal access token, I get the following error:
Logger: homeassistant.components.smartthings.config_flow
Source: components/smartthings/config_flow.py:138
integration: SmartThings (documentation, issues)
First occurred: 6:52:36 AM (1 occurrences)
Last logged: 6:52:36 AM
API error setting up the SmartApp: {'requestId': '9037093691100650629', 'error': {'code': 'ConstraintViolationError', 'message': 'The request is malformed.', 'details': [{'code': 'TargetTimeoutError', 'target': 'https://---------.myds.me/api/webhook/------------------------------------', 'message': 'Upstream target timed out', 'details': []}]}}
File "/usr/local/lib/python3.13/site-packages/homeassistant/components/smartthings/config_flow.py", line 138, in async_step_pat
app, client = await create_app(self.hass, self.api)
File "/usr/local/lib/python3.13/site-packages/homeassistant/components/smartthings/smartapp.py", line 146, in create_app
app, client = await api.create_app(app)
File "/usr/local/lib/python3.13/site-packages/pysmartthings/smartthings.py", line 110, in create_app
entity = await self._service.create_app(app.to_data())
File "/usr/local/lib/python3.13/site-packages/pysmartthings/api.py", line 171, in create_app
return await self.post(API_APPS, data)
File "/usr/local/lib/python3.13/site-packages/pysmartthings/api.py", line 395, in post
return await self.request("post", self._api_base + resource, data=data)
File "/usr/local/lib/python3.13/site-packages/pysmartthings/api.py", line 368, in request
raise APIResponseError(
...<6 lines>...
pysmartthings.errors.APIResponseError: Unprocessable Entity (422): {"requestId": "9037093691100650629", "error": {"code": "ConstraintViolationError", "message": "The request is malformed.", "details": [{"code": "TargetTimeoutError", "target": "https://-----------.myds.me/api/webhook/---------------------------", "message": "Upstream target timed out", "details": []}]}}
What am I doing wrong here?
