Can't setup Tankerkoenig (invalid config)
Hi all,
unfortunately i can’t manage to activate the Tankerkoenig integration. the config is more or less the same as the example. HA reports after reboot that the config is not valid. I’m on the latest release.
tankerkoenig:
  api_key: 3e0b2d6-abc
  fuel_types:
    - "e5"
  latitude: 49.0000
  longitude: 10.0000
  scan_interval: 900
  stations:
    - 80a64139-abc
    - 64635fc5-abc
Check the log for errors.
It’s working now after generating a new API-Key.
so, it stopped working in Home Assistant 0.108.1 after the update … “Invalid Config”
Same after update to 108.4. I tried the call manually in the browser and got a parameter error. my station that I specified in the config got a new id. -> https://creativecommons.tankerkoenig.de/TankstellenFinder/index.html
id changed and it works again
maybe you have the same problem
