Can't start Add-on Core zwave error
I can use some help fixing this error.
Could this be the reason I often (one or twice some days) need to unplug an plug in my GoControl CECOMINOD016164 HUSBZB-1 USB Hub
20-06-20 02:50:40 ERROR (MainThread) [supervisor.addons.addon] Add-on core_zwave has invalid options: Missing required option 'device'. Got {'device': None, 'network_key': ''}
20-06-20 02:50:40 WARNING (MainThread) [supervisor.addons] Can't start Add-on core_zwave:
    serial:
        /dev/ttyUSB0
        /dev/ttyUSB1
        /dev/ttyS1
        /dev/ttyS0
        /dev/ttyS3
        /dev/ttyS2
        /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_81300744-if01-port0
        /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_81300744-if00-port0
    input:
        ImExPS/2 Generic Explorer Mouse
        VirtualBox USB Tablet
        Sleep Button
        Video Bus
        AT Translated Set 2 keyboard
        Power Button
    disk:
    gpio:
    audio:
You didn’t fill out the configuration.
‘device’ needs to have it set to one of those serials.
I am getting this issues as well. Which configuration file needs to be updated. ? I can’t find that string anywhere. THanks!
Serials are located on the hardware page. The configuration is located on the gear page in the addon. There’s tabs located at the top (or bottom on mobile), one of the tabs is the configuration for the addon.
