sudo systemctl start [email protected]
I get
Failed to start [email protected]: Unit [email protected] failed to load: No such file or directory.
I did manual install on Raspbian Jessie(not lite)
I get
If you followed this guide https://home-assistant.io/getting-started/installation-raspberry-pi/ you should be able to start hass with just typing hass in the console and press enter.
If you follow this guide https://home-assistant.io/getting-started/autostart-systemd/ you will not have to manually start it each time.
I had done that but it didnt work
just went with hassbian
I have the same problem. Used Hassbian, followed the steps, and I get the same error message. SOS
