**Device model, version and app version**
Model Name: MacBookAir7,2
macOS Ve…rsion: 12.7.3
App Version: 2024.535
Safari Version: Version 17.3 (17617.2.4.11.9, 17617)
**Home Assistant Core Version**
2024.1.5
Translated Report (Full Report Below)
Process: Home Assistant [4763]
Path: /Applications/Home Assistant.app/Contents/MacOS/Home Assistant
Identifier: io.robbie.HomeAssistant
Version: 2024.1 (2024.535)
App Item ID: 1099568401
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-01-27 20:59:41.5324 +0100
OS Version: macOS 12.7.3 (21H1015)
Report Version: 12
Anonymous UUID:
Sleep/Wake UUID: 32FAB03D-89B1-4E2C-BC50-BB3E7140C351
Time Awake Since Boot: 2300 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: '/System/Library/Frameworks/ThreadNetwork.framework/Versions/A/ThreadNetwork'
Referenced from: '/Applications/Home Assistant.app/Contents/MacOS/Home Assistant'
Reason: tried: '' (no such file), '/System/Library/Frameworks/ThreadNetwork.framework/Versions/A/ThreadNetwork' (no such file)
(terminated at launch; ignore backtrace)
Thread 0 Crashed:
0 dyld 0x11cd1b9a2 __abort_with_payload + 10
1 dyld 0x11cd31ab2 abort_with_payload_wrapper_internal + 80
2 dyld 0x11cd31ae4 abort_with_payload + 9
3 dyld 0x11ccdf699 dyld4::halt(char const*) + 615
4 dyld 0x11ccdb5b5 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 3995
5 dyld 0x11ccda4e4 start + 388
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000002000209 rbx: 0x0000000000000000 rcx: 0x00007ff7b100c4b8 rdx: 0x00007ff7b100c920
rdi: 0x0000000000000006 rsi: 0x0000000000000001 rbp: 0x00007ff7b100c500 rsp: 0x00007ff7b100c4b8
r8: 0x00007ff7b100c520 r9: 0x0000000000000000 r10: 0x000000000000009f r11: 0x0000000000000246
r12: 0x000000000000009f r13: 0x00007ff7b100c920 r14: 0x0000000000000001 r15: 0x0000000000000006
rip: 0x000000011cd1b9a2 rfl: 0x0000000000000246 cr2: 0x0000000000000000
Logical CPU: 0
Error Code: 0x02000209
Trap Number: 133
Binary Images:
0x11ccd5000 - 0x11cd40fff dyld (*) <cbcd7d35-e8e9-3e64-b80b-b254b042afbf> /usr/lib/dyld
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=28.1M resident=0K(0%) swapped_out_or_unallocated=28.1M(100%)
Writable regions: Total=9540K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9540K(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
STACK GUARD 56.0M 1
Stack 8192K 1
VM_ALLOCATE 12K 3
__DATA 1808K 41
__DATA_CONST 1104K 35
__LINKEDIT 8512K 36
__TEXT 19.8M 35
dyld private memory 1024K 1
TOTAL 96.0M 153
Full Report
{"app_cohort":"2|date=1706383800000&sf=143478&tid=7b4273e23e23c26fe4144843675e984eedb8a9ba2a80de0f3f37c6ce0ef67411&ttype=e","app_name":"Home Assistant","app_version":"2024.1","timestamp":"2024-01-27 20:59:41.00 +0100","slice_uuid":"bef90aa9-01a8-3912-ba8b-9fc019a469a6","adam_id":"1099568401","build_version":"2024.535","platform":6,"bundleID":"io.robbie.HomeAssistant","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.7.3 (21H1015)","incident_id":"275440E1-DB1F-4287-822C-738054423F6A","name":"Home Assistant","is_beta":1}
"uptime" : 2300,
"procLaunch" : "2024-01-27 20:59:41.4178 +0100",
"procRole" : "Default",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookAir7,2",
"procStartAbsTime" : 2330101282127,
"coalitionID" : 2479,
"osVersion" : {
"train" : "macOS 12.7.3",
"build" : "21H1015",
"releaseType" : "User"
"captureTime" : "2024-01-27 20:59:41.5324 +0100",
"incident" : "275440E1-DB1F-4287-822C-738054423F6A",
"bug_type" : "309",
"pid" : 4763,
"procExitAbsTime" : 2330198982990,
"cpuType" : "X86-64",
"procName" : "Home Assistant",
"procPath" : "\/Applications\/Home Assistant.app\/Contents\/MacOS\/Home Assistant",
"bundleInfo" : {"CFBundleShortVersionString":"2024.1","CFBundleVersion":"2024.535","CFBundleIdentifier":"io.robbie.HomeAssistant"},
"storeInfo" : {"storeCohortMetadata":"2|date=1706383800000&sf=143478&tid=7b4273e23e23c26fe4144843675e984eedb8a9ba2a80de0f3f37c6ce0ef67411&ttype=e","itemID":"1099568401","deviceIdentifierForVendor":"BA37188A-5E8C-5424-90D3-255DBA630CEA","thirdParty":true,"entitledBeta":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "io.robbie.HomeAssistant",
"isBeta" : 1,
"sleepWakeUUID" : "32FAB03D-89B1-4E2C-BC50-BB3E7140C351",
"sip" : "enabled",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: '\/System\/Library\/Frameworks\/ThreadNetwork.framework\/Versions\/A\/ThreadNetwork'","Referenced from: '\/Applications\/Home Assistant.app\/Contents\/MacOS\/Home Assistant'","Reason: tried: '' (no such file), '\/System\/Library\/Frameworks\/ThreadNetwork.framework\/Versions\/A\/ThreadNetwork' (no such file)"]},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":40378,"threadState":{"r13":{"value":140701803268384},"rax":{"value":33554953},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":1},"r8":{"value":140701803267360},"cr2":{"value":0},"rdx":{"value":140701803268384},"r10":{"value":159},"r9":{"value":0},"r15":{"value":6},"rbx":{"value":0},"trap":{"value":133},"err":{"value":33554953},"r11":{"value":582},"rip":{"value":4778473890,"matchesCrashFrame":1},"rbp":{"value":140701803267328},"rsp":{"value":140701803267256},"r12":{"value":159},"rcx":{"value":140701803267256},"flavor":"x86_THREAD_STATE","rdi":{"value":6}},"frames":[{"imageOffset":289186,"symbol":"__abort_with_payload","symbolLocation":10,"imageIndex":0},{"imageOffset":379570,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":379620,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":0},{"imageOffset":42649,"symbol":"dyld4::halt(char const*)","symbolLocation":615,"imageIndex":0},{"imageOffset":26037,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":3995,"imageIndex":0},{"imageOffset":21732,"symbol":"start","symbolLocation":388,"imageIndex":0}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4778184704,
"size" : 442368,
"uuid" : "cbcd7d35-e8e9-3e64-b80b-b254b042afbf",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"sharedCache" : {
"base" : 140703413248000,
"size" : 19331678208,
"uuid" : "86bc6103-e387-3a89-a90f-c8314d49a242"
"vmSummary" : "ReadOnly portion of Libraries: Total=28.1M resident=0K(0%) swapped_out_or_unallocated=28.1M(100%)\nWritable regions: Total=9540K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9540K(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8192K 1 \nVM_ALLOCATE 12K 3 \n__DATA 1808K 41 \n__DATA_CONST 1104K 35 \n__LINKEDIT 8512K 36 \n__TEXT 19.8M 35 \ndyld private memory 1024K 1 \n=========== ======= ======= \nTOTAL 96.0M 153 \n",
"legacyInfo" : {
"threadTriggered" : {
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5f72dc58705eff005a46b3a9",
"factorPackIds" : {
"deploymentId" : 240000015
"rolloutId" : "6112dda2fc54bc3389840642",
"factorPackIds" : {
"SIRI_DICTATION_ASSETS" : "620aec83b02b354d3afd2f50"
"deploymentId" : 240000145
"experiments" : [
**To Reproduce**
Just upgrade to 12.7.3
**Expected behavior**
Start Normally
**Additional context**
The app was working well on MacOS 12.7.2
