Can't start multiple addons after restore - hassio crashing
Hi!
Because of instability, i’m trying to restore from a snapshot from my 64bit Hassio on to a new Pi with 32bit.
The restore runs fine, except under boot i get these messages:
18-11-01 20:44:17 ERROR (MainThread) [hassio.addons.addon] Add-on a0d7b954_logviewer can’t write options: [Errno 2] No such file or directory: ‘/data/addons/data/a0d7b954_logviewer/options.json’
18-11-01 20:44:17 ERROR (MainThread) [hassio.addons.addon] Add-on core_snips can’t write options: [Errno 2] No such file or directory: ‘/data/addons/data/core_snips/options.json’
18-11-01 20:44:17 ERROR (MainThread) [hassio.addons.addon] Add-on core_configurator can’t write options: [Errno 2] No such file or directory: ‘/data/addons/data/core_configurator/options.json’
When i try to start for example Tellstick after booting, i get the same error in the logs.
I’ve tried to uninstall the addon and installing it, but then Hass.io crashes and reboot. I’ve also tried to make the directories myself, including an empty json file, but it does not work.
Any suggestions?
Did you fix it? I’m having the same issue.
Sorry for the late reply.
I don’t remember this situation now. I think i maybe reinstalled everything and did not restore the addons, and installed them manually after this.
I’m running Home Assistant on Ubuntu on my server now.
I think I also reinstalled them, or the entire snapshot, and it worked.
