Can't start OpenZWave
Hi!
I have an Aeotec Z-Wave USB and had a couple MultiSensors. Recently I decided to get some Nano Shutters for some blinds, but when I went into my Home Assistant to add them to the network, I noticed that OpenZWave no longer starts. I’ve tried everything from removing and adding again both the Mosquitto add-on, the Zwave add-on, the MQTT and Zwave integrations, even rebooting my Raspberry Pi and changing the Aeotec USB from one port to another.
These are some of the logs that I get:
OpenZWave add-on
Mosquitto add-on
(can’t upload image bc I’m a new user)
OpenZWave integration:
Is anyone facing similar issues? What should I try to fix it?
I really don’t want the new Nano Shutters I bought go to waste :frowning_face:
What is node 10? Any way to temporarily move it away or remove power to it? See if your network starts that way. It seems something is crashing the OZW addon. And maybe it can help you jump start the new integration ZwaveJS :wink:
Thank you! Disconnecting all my nodes seems to have worked, now I only have to figure out which one was causing the issues. Once I find it, how should I re-add it to the ZWave network without causing it to crash again?
Also, The ZwaveJS add-on says it’s not available in my system, is there anything special I have to do to test it out? I’m running the HomeAssistant OS on a Raspberry Pi model 4.
You would need to install today’s new release, 2021.2.0.
Ok I just added the ZWaveJS integration, and I think I already like it more than the OpenZWave before.
BUT
I’m getting these errors when I try to control the Nano Shutters:
The ZWave integration is creating 2 entities, one “cover” and one “switch”, but neither of them seem to work.
Any ideas? :sweat_smile:
Get a dump of your zwave network and submit a github issue.
