Goodmorning,
since tried to update from 2022.3.1 to 2022.3.2 I can’t start Supervisor.
It seems to be an internal network error from host to dockers.
I can login to the web page and also SSH but, if I send any command in SSH, an error occours form dockers (connection refused): “Get “http://supervisor/network/info”: dial tcp 172.30.32.2:80: connect: connection refused”.
I can’t also login with login command and root user: it says “login incorrect”.
No way to reboot via CLI (supervisor refuses connection also here), rebooted unplugging the power ma the problem still persists.
Can you help me in solving the problem?
Thank you so much!
Here some logs. Thank you again!
*22-03-09 12:28:43 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: ._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=DockerRequestError()>
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 449, in _make_request
six.raise_from(e, None)
File “”, line 3, in raise_from
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 444, in _make_request
httplib_response = conn.getresponse()
File “/usr/local/lib/python3.9/http/client.py”, line 1377, in getresponse
response.begin()
File “/usr/local/lib/python3.9/http/client.py”, line 320, in begin
version, status, reason = self._read_status()
File “/usr/local/lib/python3.9/http/client.py”, line 281, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/local/lib/python3.9/socket.py”, line 704, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File “/usr/local/lib/python3.9/site-packages/requests/adapters.py”, line 440, in send
resp = conn.urlopen(
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 785, in urlopen
retries = retries.increment(
File “/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py”, line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/local/lib/python3.9/site-packages/urllib3/packages/six.py”, line 770, in reraise
raise value
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 703, in urlopen
httplib_response = self._make_request(
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 451, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 340, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=900)
File “/usr/src/supervisor/supervisor/docker/interface.py”, line 251, in _is_running
docker_container = self.sys_docker.containers.get(self.name)
File “/usr/local/lib/python3.9/site-packages/docker/models/containers.py”, line 897, in get
resp = self.client.api.inspect_container(container_id)
File “/usr/local/lib/python3.9/site-packages/docker/utils/decorators.py”, line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File “/usr/local/lib/python3.9/site-packages/docker/api/container.py”, line 772, in inspect_container
self._get(self._url("/containers/{0}/json", container)), True
File “/usr/local/lib/python3.9/site-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.9/site-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 542, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 529, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 645, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.9/site-packages/requests/adapters.py”, line 532, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: UnixHTTPConnectionPool(host=‘localhost’, port=None): Read timed out. (read timeout=900)
File “/usr/src/supervisor/supervisor/misc/scheduler.py”, line 62, in _wrap_task
await task.coro_callback()
File “/usr/src/supervisor/supervisor/misc/tasks.py”, line 213, in _watchdog_homeassistant_api
if not await self.sys_homeassistant.core.is_running():
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/supervisor/supervisor/docker/interface.py”, line 257, in _is_running
raise DockerRequestError() from err
supervisor.exceptions.DockerRequestError
22-03-09 12:29:17 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from a0d7b954_ssh
22-03-09 12:29:17 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from a0d7b954_ssh
22-03-09 12:29:17 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from a0d7b954_ssh
22-03-09 12:29:30 ERROR (MainThread) [asyncio] Task exception was never retrieved
response.begin()
raise value
File “/usr/src/supervisor/supervisor/misc/tasks.py”, line 347, in _watchdog_observer_docker
await self.sys_plugins.observer.is_running()
result = self.fn(*self.args, *self.kwargs)
22-03-09 12:30:06 ERROR (MainThread) [supervisor.utils] Can’t execute restart while a task is in progress
22-03-09 12:32:36 INFO (MainThread) [supervisor.api.middleware.security] /core/restart access from a0d7b954_ssh
22-03-09 12:32:36 ERROR (MainThread) [supervisor.utils] Can’t execute restart while a task is in progress
22-03-09 12:32:48 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/restart access from a0d7b954_ssh
22-0
Thank you for helping
