I’ve recently purchased a ConBee2 and am having issues with zigbee2mqtt starting…
I’ve ensured I don’t have zha currently installed (though I did ignore it when it popped up as discovered).
I’m currently running Home Assistant OS…
Here’s my log:
Zigbee2MQTT:debug 2022-06-08 00:27:59: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info 2022-06-08 00:27:59: Logging to console and directory: '/config/zigbee2mqtt/log/2022-06-08.00-27-59' filename: log.txt
Zigbee2MQTT:debug 2022-06-08 00:27:59: Removing old log directory '/config/zigbee2mqtt/log/2022-06-08.00-26-58'
Zigbee2MQTT:info 2022-06-08 00:27:59: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-08 00:27:59: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:debug 2022-06-08 00:27:59: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
2022-06-08T04:27:59.195Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2022-06-08T04:27:59.196Z zigbee-herdsman:deconz:driver Set delay to 0
CREATED DECONZ ADAPTER
2022-06-08T04:27:59.197Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyACM0","adapter":"deconz"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2022-06-08T04:27:59.198Z zigbee-herdsman:deconz:driver Opening with /dev/ttyACM0
2022-06-08T04:27:59.204Z zigbee-herdsman:deconz:driver Serialport opened
2022-06-08T04:27:59.204Z zigbee-herdsman:controller:log Started with result 'resumed'
2022-06-08T04:27:59.204Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2022-06-08T04:27:59.211Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2022-06-08T04:28:02.198Z zigbee-herdsman:deconz:adapter checking coordinator simple descriptor
2022-06-08T04:28:02.201Z zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 2 request id: 1
2022-06-08T04:28:09.213Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0xa seqNr: 1
Zigbee2MQTT:error 2022-06-08 00:28:09: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-08 00:28:09: Failed to start zigbee
Zigbee2MQTT:error 2022-06-08 00:28:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-06-08 00:28:09: Exiting...
Zigbee2MQTT:error 2022-06-08 00:28:09: undefined
[00:28:09] INFO: Zigbee Herdsman debug logging enabled
[00:28:09] INFO: Handing over control to Zigbee2mqtt Core ...
And here’s my current config yaml:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
mqtt:
server: mqtt://core-mosquitto
user: ***
password: ***
serial:
adapter: deconz
port: /dev/ttyACM0
frontend:
port: 8099
zigbee_herdsman_debug: true
Any help is GREATLY appreciated!
