I installed zbDongleP with flashed latest firmware. I have HASS on VM in a DS920+, USB passed in, I have MQTT running fine. Error is in Zigbee2MQTT log
I don’t know what this means.
[13:21:24] INFO: Handing over control to Zigbee2MQTT Core ...
Zigbee2MQTT:info 2022-09-26 13:21:27: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-26.13-21-27' filename: log.txt
Zigbee2MQTT:info 2022-09-26 13:21:27: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-26 13:21:27: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-26 13:21:52: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-26 13:21:52: Failed to start zigbee
Zigbee2MQTT:error 2022-09-26 13:21:52: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-26 13:21:52: Exiting...
Zigbee2MQTT:error 2022-09-26 13:21:52: Error: SRSP - SYS - getExtAddr after 6000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (node:internal/timers:559:17)
at processTimers (node:internal/timers:502:7)
[13:21:53] INFO: Handing over control to Zigbee2MQTT Core ...
Zigbee2MQTT:info 2022-09-26 13:21:56: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-26.13-21-56' filename: log.txt
Zigbee2MQTT:info 2022-09-26 13:21:56: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-26 13:21:56: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-26 13:22:17: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-26 13:22:17: Failed to start zigbee
Zigbee2MQTT:error 2022-09-26 13:22:17: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-26 13:22:17: Exiting...
Zigbee2MQTT:error 2022-09-26 13:22:17: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:109:5)
[13:22:18] INFO: Handing over control to Zigbee2MQTT Core ...
Zigbee2MQTT:info 2022-09-26 13:22:21: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-26.13-22-21' filename: log.txt
Zigbee2MQTT:info 2022-09-26 13:22:21: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-26 13:22:21: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-26 13:22:35: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-26 13:22:35: Failed to start zigbee
Zigbee2MQTT:error 2022-09-26 13:22:35: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-26 13:22:35: Exiting...
Zigbee2MQTT:error 2022-09-26 13:22:35: Error: SRSP - SYS - getExtAddr after 6000ms
[13:22:36] INFO: Handing over control to Zigbee2MQTT Core ...
Zigbee2MQTT:info 2022-09-26 13:22:39: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-26.13-22-39' filename: log.txt
Zigbee2MQTT:info 2022-09-26 13:22:39: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
Zigbee2MQTT:info 2022-09-26 13:22:39: Starting zigbee-herdsman (0.14.53)
Zigbee2MQTT:error 2022-09-26 13:22:59: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-09-26 13:22:59: Failed to start zigbee
Zigbee2MQTT:error 2022-09-26 13:22:59: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-09-26 13:22:59: Exiting...
Zigbee2MQTT:error 2022-09-26 13:22:59: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
[13:23:00] INFO: Handing over control to Zigbee2MQTT Core ...
I got debug logs, they’re not useful
info 2022-09-26 13:34:06: Logging to console and directory: '/config/zigbee2mqtt/log/2022-09-26.13-34-06' filename: log.txt
info 2022-09-26 13:34:06: Starting Zigbee2MQTT version 1.27.2 (commit #unknown)
info 2022-09-26 13:34:06: Starting zigbee-herdsman (0.14.53)
What’s wrong?
