fahrer17
(fahrer17)
August 13, 2021, 2:53pm
1
Hi there,
new member but not a new user - I got my HA running for a couple of months now. Not a too big configuration yes as a matter of smart devices.
My system is running on a Pi4/8GB.
I tried to install Zigbee2mqtt following these tutorials
The Zigbee2mqtt tab is only black and the system protocol keeps showing
21-08-13 16:48:07 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.4:8099 ssl:default [Connect call failed ('172.30.33.4', 8099)]
I ran out of ideas now how to solve this. Could someone help me here please?
Thank you
fahrer17
francisp
(Francis)
August 13, 2021, 3:00pm
2
What do the logs of the add-on say ?
fahrer17
(fahrer17)
August 13, 2021, 3:03pm
3
Sorry, I forgot to mention this
Zigbee2MQTT:error 2021-08-13 17:01:21: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-08-13 17:01:21: Failed to start zigbee
Zigbee2MQTT:error 2021-08-13 17:01:21: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-08-13 17:01:21: Exiting...
Zigbee2MQTT:error 2021-08-13 17:01:22: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
My Zigbee2mqtt version is 1.21.0-1 btw.
SNoof85
(Sébastien)
August 13, 2021, 3:08pm
4
So, your adapter is not seen by the addon so it wonât start. What adapter do you have ?
Check the hardware path of it, and put it correctly in the addon configuration.
francisp
(Francis)
5
Did you specify the correct port ?
schoey
August 13, 2021, 3:11pm
6
I had the same issue. I was using a CC2531 usb thingy.
I uninstalled it, uninstalled the zigbee2mqtt app.
I then installed the CC2531, and then installed the integration again and all was ok.
fahrer17
(fahrer17)
7
Itâs a Phoscon ConBee II using an USB cable, tried a USB2 port and a USB3 port with no luck.
(Wanted to add this in my initial post as well )
SNoof85
(Sébastien)
August 13, 2021, 3:12pm
8
Are you sure of the port you put in the addon config ?
And did you added :
serial:
adapter: deconz
to your config ? as stated on z2m docs
fahrer17
(fahrer17)
9
As this is not explicitly mentioned in these tutorials probably not. How do I do this?
SNoof85
(Sébastien)
August 13, 2021, 3:14pm
10
Please share your addon config (remove any login/password !)
About the port, you can find it in Supervisor => System => Host => 3 dots menu => hardware
Filter by âttyâ and post a screenshot
fahrer17
(fahrer17)
August 13, 2021, 3:19pm
11
My Zigbee2mqtt config:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.178.223:1883
user: mqtt_user
password: ***
serial:
port: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2418267-if00
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
I tried the /by-id -path as well as /dev/ttyACM0
SNoof85
(Sébastien)
August 13, 2021, 3:22pm
12
So, you are missing that part :
serial:
adapter: deconz
At the end of the ânotesâ part. And as you will see, you have the exact error message
It would give for you :
serial:
adapter: deconz
port: >-
Port looks good with serial by id. (and itâs better to use this !)
fahrer17
(fahrer17)
August 13, 2021, 3:27pm
13
Sorry, I missed this hint from you.
Added it and according to my logs I got a little further.
And I you where successful!
Thank you for your quick support! I knew HA would be the right choice
And sorry for the missing information - my kids were around
SNoof85
(Sébastien)
August 13, 2021, 3:28pm
14
Nice, problem solved then. Iâll sleep better tonight !
Cheers !
Happy zigbee
