Hi, I’m new on addon dev homeassistant, I try to Start a python discord bot with a simple addon with some options config “3” and a simple run.sh script.
But I don’t understand a part of an error, HA see my repo and list my custom addon in the addon store but can’t even get it installed and say I should see supervisor log, so I do it and there is my error, can anyone help me understand my problem?
Check my Github repo there :
I paste here my supervisor log :
22-10-31 18:08:55 INFO (MainThread) [supervisor.store] Loading add-ons from store: 296 all - 1 new - 0 remove
22-10-31 18:09:21 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/f9ca086a_discord_bot
22-10-31 18:09:21 ERROR (SyncWorker_0) [supervisor.docker.addon] Invalid build environment, can't build this add-on!
I forgot to say something, when my addon seems to start correctly my personal bot and other, I will make my addon more flexible for a public usage, like some community addon now.
But only if my bot start like on my terminal session.
Thanks.
I’m not really sure. Maybe try changing supervisor’s log level to debug (ha supervisor options --logging debug) and then try again to see if you can get some more insight? Also can you share your system info?
It’s true. Assuming we got past this I was going to suggest they switch to the python base image from here rather then adding python to the normal base image themselves.
That being said, build.yaml is entirely optional. If not specified then build_from defaults to this image (the alpine base image without python added). The only requirement is these options must be in config.yaml and the author has that. Hence why I’m a bit confused and hoping system info brings some insight.
Version core-2022.10.5
Type d'installation Home Assistant OS
Développement false
Supervisor true
Docker true
Utilisateur root
Environnement virtuel false
Version de Python 3.10.5
Famille du système d'exploitation Linux
Version du système d'exploitation 5.15.61-v8
Architecture du processeur aarch64
Fuseau horaire Europe/Paris
Répertoire de configuration /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 4887
Installed Version 1.28.2
Stage running
Available Repositories 1210
Downloaded Repositories 15
Home Assistant Cloud
Connecté false
Accéder au serveur de certificats ok
Accéder au serveur d'authentification ok
Accéder à Home Assistant Cloud ok
Home Assistant Supervisor
Système d'exploitation hôte Home Assistant OS 9.3
Mise à jour beta
Version du Supervisor supervisor-2022.10.2
Version de l'agent 1.4.1
Version de Docker 20.10.18
Taille total du disque 229.2 GB
Taille du disque utilisé 131.4 GB
Sain true
Prise en charge Unsupported
Tableau de bord rpi4-64
API du Supervisor ok
Version API ok
I try locally to make a build.yaml or build.json but seems change nothing
Did I forgot something in config.yaml ? Like url description ?
