Can't turn off running script
I have a script (loop) that I am not able to turn off once I start it.
  fire:
    sequence:
      - service: light.turn_on
        data_template:
          entity_id: light.ls1
          rgb_color: [255, '{{ (range(0, 100)|random) }}', 0]
          brightness: '{{ (range(50,255)|random) }}'
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
      - service: script.turn_on
          entity_id: script.spark
  spark:
    sequence:
          entity_id: script.fire
  ash:
    sequence:
      - service: script.turn_off
In customize I have:
  script.fire:
    can_cancel: true
So I have the switch to turn it off and I also have the script ash to turn it off, but both options simply don’t work. The script just turns itself on again after half a second and the only way to stop it is to reload scripts under Configuration/General/
I do have another looping script (with delays in there) that I can turn off without any problem. But I don’t want delays in this one.
Change spark to…
  spark:
    sequence:
      - service script.turn_off
      - service: script.fire
Sadly, that did not work.
I did get it to work with putting in the shortest delay possible (?)
  fire:
    sequence:
        data_template:
      - delay:
          milliseconds: 1
  spark:
    sequence:
  ash:
    sequence:
BUT that slows down the effect too much for what I want to achieve. So then I duplicated the “service: light.turn_on” a bunch of times like in the previous example, to have the delay only like every 20th time. But then it’s the same as before, I can’t turn the script off, once it started running.
