Hi, I am Home Assistant newbie from Tokyo.
Lately I have purchased some MagicHome compatible right which I expect to use with flux_led platform. However, I can not turn on these light at once, but one by one.Here are some example script but this behavior applies to automation too.
turn_on_2f_lights_at_once:
sequence:
- service: light.turn_on
entity_id: light.table,light.living_s,light.living_e,light.kitchen_s
I want to turn on these 4 rights together, but when I trigger this script only one of them will be turned on. In this example, light.living_e is always turned on.
turn_on_2f_lights_one_by_one:
sequence:
entity_id: light.living_s
entity_id: light.living_e
entity_id: light.kitchen_s
Then I finally figured out(?) this can work, but this would just turn on lights one by one - but better than previous example, so I am also using multiple services on my automation. Also interestingly, this needs 7 seconds of delay between each light.turn on when I trigger. I am assuming if Home Assistant can not send packet to turn_on packet to more than one flux_led at once. Have you ever experienced this behavior or can you point out if my configuration is wrong?
And light.turn_off can turn off multiple flux_leds at once, this works perfectly.
Thanks.
