I have home assistant supervised on a docker on debian buster
I can’t update core with this error.
ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2021.11.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2021.11.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant: Internal Server Error ("Get https://ghcr.io/v2/: dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:58136->[::1]:53: read: connection refused")
Someone can help me to understand this error ?
Thank’s
freshmeat
(freshmeat)
2
Hi, same problem here. Did you solve the problem?
Ty
Hi, I have the same error can’t update from core-2021.11.1 to core-2021.11.4.
21-11-19 22:08:40 ERROR (SyncWorker_2) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2021.11.4: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2021.11.4&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant: Internal Server Error (“Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
21-11-19 22:08:40 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
