Cant update core from 0.113.3
I know that I’m late to update, but as I’m now on version 0.113.3 of the core I need to update, but it doesn’t seems to work.
I’ve updated both the OS(9.2) and the Supervisor(2022.10.0) to the latest version.
But when I try to update core i looks like everything is good, but when I check with core info after the update it’s the same version as before. I’ve tried with both a specific version and just to update to the latest.
Does anyone know if it is possible to update from 0.113.3 to latest version?
I was thinking if it is possible to do it one version at the time , so first go to 0.114.1 and the 0.115.1 and so on, is that possible?
Maybe I have updated the OS and Supervisor to fast so they not are in sync with the core?
But the system is healthy if I check Supervisor info.
So can someone help me with this?
The problem for me was that my router (Netgear) blocked some of the sites that are used for update of the core.
So if someone has the same problem. check if you have a netgear router, and change if you have.
