Can't update core, Timeout while processing CodeNotary
I’m running core-2022.3.2 on Home Assistant OS 7.4
When I try to update to 2022.3.3, it fails with the following error in the logs:
22-03-09 17:40:52 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
It appears that the file was successfully downloaded.
22-03-09 17:40:21 INFO (SyncWorker_8) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2022.3.3.
Any thoughts?
Ah. Found this:
