Cant update from Home Assistant Core 2023.12.2
Hi all
I’ve tried several times to install the 2024.1.x and 2024.2.x updates but they always fail. I’m running latest official versions of OS and supervisor on a Raspberry pi 4, using an SSD for the system drive. Hard reboot didn’t help.
  • Core2023.12.2
  • Supervisor2024.01.1
  • Operating System11.5
  • Frontend20231208.2
The supervisor log says:
24-02-20 14:02:03 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
24-02-20 14:02:03 CRITICAL (MainThread) [supervisor.homeassistant.core] HomeAssistant update failed → rollback!
the rollback log is a bit longer, but still not much help to me
2024-02-20 08:44:45.407 ERROR (MainThread) [root] Uncaught exception
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 221, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 188, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 684, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 192, in async_setup_hass
    config_dict = await conf_util.async_hass_config_yaml(hass)
  File "/usr/src/homeassistant/homeassistant/config.py", line 502, in async_hass_config_yaml
    await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
  File "/usr/src/homeassistant/homeassistant/config.py", line 1030, in merge_packages_config
    PACKAGES_CONFIG_SCHEMA(packages)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 589, in verify
    return cast(dict, schema(value))
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['scene']
I have tried searching the internet and this forum, but have been unable to find anything helpful
I would be grateful if anyone can help me!
