Tried updating several times to different version up to the current 0.84.1
Select update from hassio tab. After about 10 mins home assistant becomes unavailable.
Then about 20 mins later it is back online but no update has happened still offering update.
Running Hassos 1.13 and hassio supervisor 141.
any ideas or is the a rebuild of the latest version and snapshot restore
Log file shows
2018-12-13 21:45:45 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-12-13 21:45:50 WARNING (Recorder) [homeassistant.components.recorder.migration] Database requires upgrade. Schema version: 7
2018-12-13 21:45:50 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=1 from 2018-12-13 21:24:25.595770)
2018-12-13 21:45:53 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-13 21:45:57 ERROR (MainThread) [homeassistant.components.sensor] cpuspeed: Error on device update!
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 251, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/cpuspeed.py", line 85, in update
self._state = round(float(self.info['hz_actual_raw'][0])/10**9, 2)
KeyError: 'hz_actual_raw'
2018-12-13 21:48:05 WARNING (MainThread) [homeassistant.core] Unable to find service remote/send_command
2018-12-13 21:48:18 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:12
