Hey guys Im trying to update HA and being meet with roadblock after roadblock. Ive tried via GUI and CLI says “ERROR Check logs” GUI says the following,
18-11-29 12:22:54 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.83.3 18-11-29 12:22:54 INFO (SyncWorker_3) [hassio.docker.interface] Update Docker 0.82.1 with homeassistant/raspberrypi3-homeassistant:0.83.3 18-11-29 12:22:54 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.83.3. 18-11-29 12:22:54 ERROR (SyncWorker_3) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.83.3 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:38250->[::1]:53: read: connection refused”). 18-11-29 12:22:54 WARNING (MainThread) [hassio.homeassistant] Home Assistant is already running! 18-11-29 12:22:54 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.83.3
I have a Pi3 with a 32gb flash,
Ethernet, to a 3850 Cisco
Last Resort is Palo 220 with HA ip in a policy allowing any any egress
Here is my storage
debug1: permanently_set_uid: 0/0
core-ssh:~# df -h
Filesystem Size Used Available Use% Mounted on
overlay 28.6G 15.5G 11.6G 57% /
tmpfs 64.0M 0 64.0M 0% /dev
tmpfs 463.1M 0 463.1M 0% /sys/fs/cgroup
/dev/root 80.4M 80.4M 0 100% /dev/init
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /share
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /data
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /config
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /ssl
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /addons
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /backup
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /etc/resolv.conf
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /etc/hostname
/dev/mmcblk0p8 28.6G 15.5G 11.6G 57% /etc/hosts
shm 64.0M 0 64.0M 0% /dev/shm
tmpfs 64.0M 0 64.0M 0% /proc/keys
tmpfs 64.0M 0 64.0M 0% /proc/latency_stats
tmpfs 64.0M 0 64.0M 0% /proc/timer_list
tmpfs 64.0M 0 64.0M 0% /proc/sched_debug
tmpfs 463.1M 0 463.1M 0% /sys/firmware
Any help would be gratefully appreciated.
Thank You
Phillip
