Cant update HACs something to do with Host?
i trying to update my one home assistant hacs… from 2.0.0. to 2.0.1 it wont let me it keeps throwing me time out errors etc… is there a way to install it manually… command line install it etc? download it and manually copy … or what is blocking it?
This error originated from a custom integration.
Logger: custom_components.hacs
Source: custom_components/hacs/repositories/base.py:984
integration: HACS (documentation, issues)
First occurred: 7:31:00 PM (5 occurrences)
Last logged: 8:00:18 PM
<Integration hacs/integration> Failed to download https://github.com/hacs/integration/releases/download/tags/2.0.1/hacs.zip
Source: custom_components/hacs/base.py:714
First occurred: 7:26:51 PM (25 occurrences)
Last logged: 8:00:17 PM
    A timeout of 60! seconds was encountered while downloading https://github.com/hacs/integration/releases/download/2.0.1/hacs.zip, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 4
    A timeout of 60! seconds was encountered while downloading https://github.com/hacs/integration/releases/download/2.0.1/hacs.zip, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 3
    A timeout of 60! seconds was encountered while downloading https://github.com/hacs/integration/releases/download/2.0.1/hacs.zip, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 2
    A timeout of 60! seconds was encountered while downloading https://github.com/hacs/integration/releases/download/2.0.1/hacs.zip, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 1
    A timeout of 60! seconds was encountered while downloading https://github.com/hacs/integration/releases/download/2.0.1/hacs.zip, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
so what would be going on?
and i just updated to HA 2024.9.1
that popped up tonight… i figured it would solved the issue but it didnt solve the problem
Did you find a solution to this? I’m running into the same thing.
