Can't update Home Assistant Core OR restore from previous backup
I’m having an issue updating Home Assistant Core from 2023.1.5 to 2023.1.7. I receive the error Error: 'HomeAssistantCore.update' blocked from execution, no host internet connection although my internet connection is fine. I tried changing the DNS server to 8.8.8.8 and updating from the terminal, but that didn’t work either.
I then had a look in the core log which gave me the following output:
2023-02-01 12:14:00.392 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140625138209584] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 303, in async_install
    await async_update_core(self.hass, version=version, backup=backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 51, in _wrapper
    raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, no host internet connection
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1755, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1792, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 958, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 305, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, no host internet connection
I had no idea where to even begin solving this, so I decided to restore a previous backup and try updating again, but for some reason I’m unable to do so as well. The UI doesn’t show any activity at all when I click on restore, and from the terminal, it instantly says Command completed successfully, but the backup is not restored. I had a look in the supervisor log and found this output:
23-02-01 12:13:35 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, no host internet connection
23-02-01 12:14:00 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, no host internet connection
23-02-01 12:18:54 INFO (MainThread) [supervisor.backups.manager] Found 80 backup files
23-02-01 12:19:06 INFO (MainThread) [supervisor.jobs] 'BackupManager.do_restore_full' blocked from execution, no host internet connection
23-02-01 12:22:01 INFO (MainThread) [supervisor.jobs] 'BackupManager.do_restore_full' blocked from execution, no host internet connection
23-02-01 12:22:29 INFO (MainThread) [supervisor.jobs] 'BackupManager.do_restore_full' blocked from execution, no host internet connection
I’ve also tried to reload the network ha network reload which did not work either. The network info returns host_internet: false, no matter what do. Here is the output from ha network info:
docker:
  address: 172.30.32.0/23
  dns: 172.30.32.3
  gateway: 172.30.32.1
  interface: hassio
interfaces:
- connected: true
  enabled: true
  interface: enp0s18
  ipv4:
    address:
    - 10.0.40.2/24
    gateway: 10.0.40.1
    method: static
    nameservers:
    - 8.8.8.8
    ready: true
  ipv6:
    address:
    - fe80::663c:160a:8eb2:6ea1/64
    gateway: null
    method: disabled
    nameservers: []
    ready: true
  primary: true
  type: ethernet
  vlan: null
  wifi: null
supervisor_internet: true
Has anyone faced a similar issue or have any ideas on how to solve this problem?
Thanks in advance for your help!
Hi.
Well… I guess it makes sense when you give more details about your setup. Because Core and Docker? I do not get the point here.
There are two alternative installation methods available for experienced users:
    Home Assistant Supervised: Manual installation of the Supervisor.
    Home Assistant Core: Manual installation using Python virtual environment.
Ref: Installation - Home Assistant
Normaly I would not expect this in a container. But well… Tried to connect to the container and checked the network?
I had the same problem, was proxy server redirecting http port 80.
Disabled proxy & ha network reload fixed it for me.
