Hello HAGurus!
Well… I’ve been running HA for about 3 years now. All updates so far have been pretty straight forward but for some reason, I just can’t update past 2023.4.6 and I can’t figure out why.
I’ve been staring at log files, configurations, add-ons and pinballing around everything I can think of to get an idea of what’s going on but I think at this point, I’ve got so far into the diagnostic process that I’ve lost sight of probably what’s staring at me in the face waving at me!
So… from the top:
I’m running HA on a VM inside a Qnap.
Storage - fine
Resources - fine
System firmware - up to date -
Inside the HA console I’ve run:
- ha core check - checked ok
- ha core rebuild - error -
23-06-17 12:41:49 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
23-06-17 12:41:52 WARNING (raven-sentry.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f3f78e6bb90>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/
23-06-17 12:41:52 WARNING (raven-sentry.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f3f780bab50>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/
23-06-17 12:41:52 WARNING (raven-sentry.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f3f7aa1ced0>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/
23-06-17 12:41:54 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
ha core update - Processing - Done. Command completed successfully.
ha core available-updates:
panel_path: /update-available/core
update_type: core
version_latest: 2023.6.2
Yet when I look in the GUI, it says that the update is still pending.
Can anyone shed any light as to why it won’t update?
Thanks in advance.
