I have a recent home assistant image installed on a raspberry pi 4 with 2 gb ram on a 32 gb card. I tried to update core from the UI. Update finished but supervisor wouldn’t open on the UI. I ssh’d in and and restored a snapshot. Not sure what happened. Logs not helpful (checked before restoring snapshot) . So, I installed the configuration checker, and it ran fine showing no errors. Then I tried to update the supervisor first this time, but it fails saying “no such image.”
Research showed this was a problem in virtual machines and the host storage needed enlarged. My microsd is plenty big enough. My understanding after first boot it should have grown the containers/partition to better take use of the space.
How do I fix this problem? I’m pretty facile with Linux being a user for around 23 years, command line junky, and self-taught python programmer. That said, I’ve not educated myself on docker containers so would need a bit of hand holding if I need to grow or enter a container.
Help is greatly appreciated.
I have core, super, and host info if needed and of course the super log showing the full python Traceback if needed.
The full error message would be rather useful There’s various possible reasons for that kind of message, but each of the causes results in a different message.
[32m20-06-25 00:21:32 INFO (SyncWorker_13) [supervisor.docker.cli] Start CLI homeassistant/armv7-hassio-cli with version 25 - 172.30.32.5 [0m
[32m20-06-25 00:21:32 INFO (SyncWorker_6) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 14 - 172.30.32.4 [0m
[32m20-06-25 00:21:32 INFO (SyncWorker_8) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 9 - 172.30.32.3 [0m
[32m20-06-25 00:21:32 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf [0m
[32m20-06-25 00:21:32 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json [0m
[32m20-06-25 00:21:34 INFO (SyncWorker_15) [supervisor.docker.interface] Attach to homeassistant/raspberrypi4-homeassistant with version 0.111.4 [0m
[32m20-06-25 00:21:34 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on / [0m
[32m20-06-25 00:21:34 INFO (MainThread) [supervisor.hassos] Detect HassOS 3.13 / BootSlot A [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 65 new - 0 remove [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.addons] Found 5 installed add-ons [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_10) [supervisor.docker.interface] Attach to hassioaddons/adguard-armv7 with version 2.4.1 [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_11) [supervisor.docker.interface] Attach to hassioaddons/wireguard-armv7 with version 0.3.2 [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_7) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 5.0.0 [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_19) [supervisor.docker.interface] Attach to hassioaddons/ssh-armv7 with version 7.4.1 [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-duckdns with version 1.12.0 [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.snapshots] Found 8 snapshot files [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.discovery] Load 1 messages [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.ingress] Load 0 ingress session [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 1 [0m
[32m20-06-25 00:21:35 INFO (MainThread) [__main__] Run Supervisor [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2 [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.utils.gdbus] Call de.pengutronix.rauc.Installer.Mark on / [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good [0m
[32m20-06-25 00:21:35 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 227 [0m
[32m20-06-25 00:21:35 INFO (SyncWorker_13) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-supervisor tag 227. [0m
[31m20-06-25 00:23:06 ERROR (SyncWorker_13) [supervisor.docker.interface] Can't install homeassistant/armv7-hassio-supervisor:227 -> 404 Client Error: Not Found ("no such image: homeassistant/armv7-hassio-supervisor:227: No such image: homeassistant/armv7-hassio-supervisor:227"). [0m
[31m20-06-25 00:23:06 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor fails! [0m
[31m20-06-25 00:23:06 CRITICAL (MainThread) [supervisor.core] Can't update supervisor! This will break some Add-ons or affect future version of Home Assistant! [0m
[32m20-06-25 00:23:06 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons [0m
[32m20-06-25 00:23:06 INFO (MainThread) [supervisor.addons] Phase 'system' start 0 add-ons [0m
[32m20-06-25 00:23:06 INFO (MainThread) [supervisor.addons] Phase 'services' start 3 add-ons [0m
[33m20-06-25 00:23:06 WARNING (SyncWorker_17) [supervisor.docker.addon] SSH & Web Terminal run with disabled protected mode! [0m
[32m20-06-25 00:23:07 INFO (SyncWorker_7) [supervisor.docker.addon] Start Docker add-on hassioaddons/adguard-armv7 with version 2.4.1 [0m
[32m20-06-25 00:23:07 INFO (SyncWorker_17) [supervisor.docker.addon] Start Docker add-on hassioaddons/ssh-armv7 with version 7.4.1 [0m
[32m20-06-25 00:23:08 INFO (SyncWorker_18) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-duckdns with version 1.12.0 [0m
[32m20-06-25 00:23:09 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_adguard [0m
[32m20-06-25 00:23:10 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_ssh [0m
[32m20-06-25 00:23:13 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_adguard [0m
[32m20-06-25 00:23:13 INFO (SyncWorker_14) [supervisor.docker.interface] Start homeassistant/raspberrypi4-homeassistant [0m
[32m20-06-25 00:23:30 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance [0m
[32m20-06-25 00:23:30 INFO (MainThread) [supervisor.addons] Phase 'application' start 2 add-ons [0m
[32m20-06-25 00:23:32 INFO (SyncWorker_16) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 5.0.0 [0m
[32m20-06-25 00:23:32 INFO (SyncWorker_9) [supervisor.docker.addon] Start Docker add-on hassioaddons/wireguard-armv7 with version 0.3.2 [0m
[32m20-06-25 00:23:34 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_wireguard [0m
[32m20-06-25 00:23:36 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_wireguard [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardware monitor [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.core] Supervisor is up and running [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.host.info] Update local host information [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1 [0m
[32m20-06-25 00:23:37 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json [0m
[32m20-06-25 00:23:38 INFO (MainThread) [supervisor.host.services] Update service information [0m
[32m20-06-25 00:23:38 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1 [0m
[32m20-06-25 00:23:38 INFO (MainThread) [supervisor.host.network] Update local network DNS information [0m
[32m20-06-25 00:23:38 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager [0m
[32m20-06-25 00:23:38 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information [0m
[32m20-06-25 00:55:31 INFO (MainThread) [supervisor.api.security] /supervisor/info access from a0d7b954_ssh [0m
[32m20-06-25 00:56:10 INFO (MainThread) [supervisor.api.security] /core/info access from a0d7b954_ssh [0m
[32m20-06-25 00:58:40 INFO (MainThread) [supervisor.api.security] /supervisor/info access from a0d7b954_ssh [0m
[32m20-06-25 01:00:06 INFO (MainThread) [supervisor.api.security] /supervisor/repair access from a0d7b954_ssh [0m
[32m20-06-25 01:00:06 INFO (MainThread) [supervisor.core] Start repairing of Supervisor Environment [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_19) [supervisor.docker] Prune stale containers [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_19) [supervisor.docker] Prune stale images [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_19) [supervisor.docker] Prune stale builds [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_19) [supervisor.docker] Prune stale volumes [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_19) [supervisor.docker] Prune stale networks [0m
[32m20-06-25 01:00:06 INFO (MainThread) [supervisor.plugins.cli] Repair HA cli 25 [0m
[32m20-06-25 01:00:06 INFO (SyncWorker_6) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-cli tag 25. [0m
[32m20-06-25 01:00:14 INFO (SyncWorker_6) [supervisor.docker.interface] Tag image homeassistant/armv7-hassio-cli with version 25 as latest [0m
[32m20-06-25 01:00:14 INFO (MainThread) [supervisor.addons] Found 0 add-ons to repair [0m
[32m20-06-25 01:00:14 INFO (MainThread) [supervisor.supervisor] Repair Supervisor 224 [0m
[32m20-06-25 01:00:14 INFO (MainThread) [supervisor.core] Finished repairing of Supervisor Environment [0m
[32m20-06-25 01:01:30 INFO (MainThread) [supervisor.api.security] /supervisor/stats access from a0d7b954_ssh [0m
[32m20-06-25 01:02:08 INFO (MainThread) [supervisor.api.security] /supervisor/update access from a0d7b954_ssh [0m
[32m20-06-25 01:02:08 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 227 [0m
[32m20-06-25 01:02:08 INFO (SyncWorker_1) [supervisor.docker.interface] Pull image homeassistant/armv7-hassio-supervisor tag 227. [0m
[31m20-06-25 01:03:03 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/armv7-hassio-supervisor:227 -> 404 Client Error: Not Found ("no such image: homeassistant/armv7-hassio-supervisor:227: No such image: homeassistant/armv7-hassio-supervisor:227"). [0m
[31m20-06-25 01:03:03 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor fails! [0m
[32m20-06-25 01:04:36 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from a0d7b954_ssh [0m
Hello.
I have the same error when i tried touppgrade from 109.6 to 111.4 and other.
After i install 109.6 i cant upgrade. Tried several times.
I run hassio on virtualbox. I have tried to extend memory 1GB and HDD 100GB. Still same error.
Log.
20-06-26 06:25:51 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:0 is not WSMsgType.TEXT
20-06-26 06:25:51 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-06-26 06:25:57 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-06-26 06:25:57 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-06-26 06:25:57 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
20-06-26 19:33:32 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.111.4
20-06-26 19:33:32 INFO (SyncWorker_3) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.109.6 to homeassistant/qemux86-64-homeassistant:0.111.4
20-06-26 19:33:32 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.111.4.
20-06-26 19:33:35 ERROR (SyncWorker_3) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.111.4 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.111.4: No such image: homeassistant/qemux86-64-homeassistant:0.111.4”).
20-06-26 19:33:35 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
I have the same problem but with a RPI 4: it’s a week I can see the update button but the result is this:
2022-01-12 02:22:06 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /os/update - Can’t fetch OTA update from https://github.com/home-assistant/operating-system/releases/download/7.1/haos_rpi4-64-7.1.raucb:
But if I try to download the file I can. Is it possible to update from a USB key?
It’s not a space problem I have 450Gb free.
