Cant Update Node Red to V19.0.0
Hello, because my Node Red suddenly has problems with some elements (after I disconnected it from the power supply). I wanted to bring the system up to date.
It all runs on raspberry pi 4, at that time with the finished HACS image.
Core 2025.1.4
Supervisor 2024.12.3
Operating System 14.1
Frontend 20250109.2
The error message appears that
‘The update/install action could not be executed. Error updating Node-Re: Add-on a0d7b954_nodered not supported on this platform, supported architectures: aarch64, amd64.’
I thought a raspberry pi 4 is still supported ?!
What am I doing wrong?
Small self-assessment: DAU
Translates German-> English with deepL
Translated with DeepL.com (free version)
The pi4 is 64 bit. It seems you have a 32 bit version of home assistant os installed though. To check install the glances addon, start it, open the web UI. Top left hand corner it should say if the os is 32 bit.
If it is then you would need to do a complete backup, move it off home assistant. Flash the 64 bit OS and restore your backup.
Thx, yore right! 32bit version
